OPEN/READ ATTACHED FILE
Taki1999 Dear Friend,
With your suggestion, you helped me create the vi. Now I can improve my work! Smiley Happy
Thanks to everyone that we are helping me !!!!
Message 21 of 42
(878 Views)
Next up, use the code cleanup tool to clean up that piece of code.  It will eliminate the extra white space and make it more readable so that you don't have wires weaving back and forth and running in a backwards direction, straightening them how and making the code look neater.
Message 22 of 42
(875 Views)
There is also no need to resort to using a formula node for such a trivial calculation.
Message 23 of 42
(872 Views)
Yes, try something like this....
Message 24 of 42
(859 Views)
Dear Friend "Knight of NI" ,
I added a timer (wait - ms) in its suggestion of VI. The work was excellent! Smiley Happy
Please, could you suggest how to transform the data string [abc] in a XY Chart (time x variable 1 - variable 2 - variable 3 ... etc)? I'm not able to develop it!!! Smiley Sad
Message 25 of 42
(841 Views)
WHy did you make the diagram constants orange? They are integers!
Message 26 of 42
(826 Views)
Here's one suggestion of what could go in your subset processing code.
I'll leave it as an exercise for the reader for adapting this for more datasets or variable numbers of datasets.  (Hint: see my previous message and use of shift registers.)
Message 27 of 42
(823 Views)
Dear Friend Knight of NI,
I am beginner. I was really wrong! Thanks for the correction!
If you can help me how to present data in chart form in vi, I'll be more grateful! Smiley Happy
Thanks!
Message 28 of 42
(817 Views)
Taki1999,
Thanks for the suggestion!
I'll try! Smiley Happy
Thanks!
Message 29 of 42
(812 Views)
Here's a simple way to read it (LabVIEW 8.6).
(At the moment I assume a constant dx of 2 seconds and ignore the time column for simplicity, modify as needed)
(Note that "scan strings for tokens has the cool feature that consecutive delimiters are collapsed into one. This is a feature that would also be useful elsewhere (See here!), so please support my idea!))
Message 30 of 42
(806 Views)
