So You Are able to write data in N 0:0 I think You are writing on Modbus address Is it ?
As I had connected Mitshubishi PLC to Ni OPC server Easily, Where We could directly read write onto their Register.
(Say D words (D100) as well as Boolean M Bit (M 100)).
So I am Sure you can do read write directly in Allen Bretly PLC.
That Is sure.
May be you might be selecting wrong driver.
Because, after selecting driver just create one Device and then create tag. In that tag whatever the Register terminology you use for the PLC will pop up while creating tags. Like in Mitshubishi we had D words, Boolean For M bit, Network Register were W and B Bit.
So I think Just check, u might be making mistake with driver selection.
Thank U so much for putting post.
Brijesh Patel
CLAD
Labiew programmer
