OPC UA Get Node Attribute only returns datatype: 24
Hello all,
I have an OPCUA server that I'm trying to read data from. The datatypes on the server vary, so there's floats, UInt16's ect.
If I connect to the server using an application such as UA Expert it shows different nodes as different data types, however, if I browse these nodes in LabVIEW using Get Node Attribute the Datatype value is 24. This is unexpected, as everything has the same datatype, and also datatype 24 is not listed as value on the help page.
Anyone know what could be causing this?
Cheers,
Gazebo
______________________________________________________________
(5,252 Views)
Here's the code and UA Expert view showing the datatype as UInt32
As you can see on the Get Node Attribute help page, 24 is not listed as a datatype: http://zone.ni.com/reference/en-XX/help/371618J-01/lvmve/opcua_get_attri/
UInt32 should correspond to a datatype of 7.
(5,241 Views)
Hello Gazebo,
Is "Get Node Attribute VI" returning any error code?
Jovan N. - Application Engineering
(5,132 Views)
There is no error message. The other attributes seem correct, just the datatype value remains the same.
(5,116 Views)
Could you confirm me that, by ading an indicator in "Get Node Attribute VI" error node, there are not error messages?
BR,
(5,090 Views)
Sure!
(5,078 Views)
Here's the output of the GetNodeAttribute vi itself. <24> is not even a value in the Datatype enum.
(5,051 Views)
