05-10-2021 02:25 AM - edited 05-10-2021 02:27 AM
I have an issue with the connection to a local TwinCAT OPC UA Server.
I am running a machine, in which two industrial computers are 100% identical.
My problem is that using the NI OPCUA (2017) Client.lvlib:Connect.vi to connect to a local OPC UA server, in one computer it takes about 1 second and in the other one 10 seconds (e.g. in screenshots).
Both the computers run on Windows 7 and are using LabVIEW 2017.
Did anyone have a similiar issue and might know where it comes from?
Best regards
05-28-2021 04:48 AM
after upgrading to Windows 10 the connection issue was gone.
This thread can be closed.
Thank you,
David
05-28-2021 05:08 AM
Thanks for sharing the solution to the problem.
05-28-2021 05:54 AM
You can also mark your own post as a solution.
