07-28-2019 09:29 AM
Guys, i need help in installing IO server..
i have installed NI OPC SERVER and DATA LOGGING AND SUPERVISORY CONTROL module in PC.. Yet i'm not able to find IO SERVER when i open a project.. I have even installed labVIEW real time module too.. still i can't get the IO SERVER.. what should i do to get the IO server in project??
07-29-2019 12:18 AM
I met same issue several years ago and i find a solution from the fourms:
Just re-install the NI MAX to fix the problem.
Hope it can help you
