The following webpage contains sound card VIs:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/b50a37358204d4078625667a005179c1?OpenDocument
You could use the Sound In VI's to record the sound. Then, you can use the digital filtering VIs (in either Full or Professional versions of LabVIEW) to filter out the high frequencies.
