02-22-2008 07:40 PM
02-28-2008 09:43 AM
Hi David why are you changing the communication from RS232 to RS485?, Maybe you could use some extra serial RS232 ports in your computer ? Here the main subject would be if your OPC server has support for the RS485. Also there are several providers of Omron Host link OPC server. In most of them you would be able to control one PLC with a serial port, or several depending on the communication method. For example with the Klinkmann version:
"The following steps are taken to define the topics (controllers) connected to OMRHLINK
Server. The connection can be direct (default) if communicating with controller via serial
or multi-dropped serial configuration or networked if communicating with controller that is
on some of OMRON FA (Factory Automation) networks (e.g. Ethernet or Controller Link)"
http://www.klinkmann.com/CD/doc/480XXM10.PDF
Still it might be easier to configure if you use a RS232 Port for the each PLC, if you dont have enough ports, we have PCI, or USB Serial ports:
Hope this helps
