Numerical integration of Force and Velocity graphs to obtain energy.
Hello Respected Members!
I am presently working on Force Velocity integration to obtain energy of a falling hammer. I have attached two accelerometers and two strain guages to a rod, on which the hammer shall fall. I have attached the pictures which better explain the problems.
i m using Ni-cDaq 9172 and NI9237 ( accelerometers are piezoresistive)
Please advise how to go about it.
(3,469 Views)
Hi Ahmed,
on the integration part:
Integration of discrete samples is just the sum of sample value * dt (sampling interval) in the simplest implementation. LabVIEW also provides functions to do the integration of waveform data…
On your triggering problem:
- You might set an analog start trigger in your DAQmx task when the hardware supports such triggers.
- You might analyze your data after sampling to find the triggers on your own. Most often it's a simple threshold limit of the signal, sometimes you can also use the derivation of the signal…
What have you tried so far?
Where are you stuck?
(3,459 Views)
I have generated a graph which ideally should be for the force and velocity. but how to do the integration of both with respect to time. i am attaching a vi.
please advise how to record these graphs into separate columns(arrays perhaps), which can later be used to plot a graph based on different energies in each hammer blow.
Kindly correct me if i have done the integration the right way.
i am attaching the formula as well..
(3,437 Views)
Once you have data that appears to be correct, you could log that data to an Excel or TDMS file for post-analysis.
Applications Engineering
(3,421 Views)
Accepted by Ahmed.Arsalan
Hi Ahmed,
Right now you seem to have used the right ExpressVIs in the right order.
(I wouldn#t call this "programming", but just "configuring"…)
There are more ExpressVIs, even ones for saving data to files…
(3,417 Views)
Thanks alot sir.
One last query is, how i can configure a software trigger on of the source , that is strain guage, and with that trigger , the accelerometer reading also starts, take 10k samples and auto stop.
(3,414 Views)
