04-21-2014 12:01 AM
Hello everyone,
I am new to LabVIEW. I recently wrote a LabVIEW block diagram that is used to collect data from 3 different sensors which are connected to the same DAQ. My block diagram outputs the data into a spread sheet. The issue I have is that the time column contains the time in the following format (00:00:00:00). All the values in the column are in the same format with a 0.01 seconds difference from the previous values. I'd like the output to my time data column in the spreadsheet at least in a numeric form (0, 0.01, 0.02, 0.03, etc) while sticking with the waveform.
Is that possible and how to do so?
Thank you and regards
04-21-2014 12:44 AM
04-21-2014 12:46 AM
I'm using "Export waveform to spreadsheet"
04-21-2014 12:50 AM
