Num control starts over with the mouse wheel
I made a couple of posts here about scrollwheels on arrays. Its a different use case but you can probably still use the "delta" from the event data to achieve what you need.
https://forums.ni.com/t5/LabVIEW/Don-t-allow-mouse-wheel-to-scroll-the-vertical-scrollbar-after/m-p/...
Have a play with and see what you can come up with 🙂
0xDEAD
Message 11 of 15
(238 Views)
I listened to deceased and here is what I did. It is a workaround the issue but it should work and it's easy to add in the program.
I disabled the "built-in wheel mouse support" in the proprieties of the controls
Thank you all
Yddet
Message 12 of 15
(229 Views)
Just a reminder to be careful with the "in range" function's default limits: upper limit is not included lower limit is..
ʍolɟɐʇɐp ʞuıɥʇ
Message 13 of 15
(225 Views)
Yes, its a good point to remember!  Black diamond indicates included, open diamond is not. They are settable in the right click context menus.
0xDEAD
Message 14 of 15
(216 Views)
Good to know, I never noticed that.
Message 15 of 15
(201 Views)
