Num control starts over with the mouse wheel
I made a couple of posts here about scrollwheels on arrays. Its a different use case but you can probably still use the "delta" from the event data to achieve what you need.
https://forums.ni.com/t5/LabVIEW/Don-t-allow-mouse-wheel-to-scroll-the-vertical-scrollbar-after/m-p/...
Have a play with and see what you can come up with 🙂
0xDEAD
Message 11 of 18
(1,156 Views)
I listened to deceased and here is what I did. It is a workaround the issue but it should work and it's easy to add in the program.
I disabled the "built-in wheel mouse support" in the proprieties of the controls
Thank you all
Yddet
Message 12 of 18
(1,147 Views)
Just a reminder to be careful with the "in range" function's default limits: upper limit is not included lower limit is..
ʍolɟɐʇɐp ʞuıɥʇ
Message 13 of 18
(1,143 Views)
Yes, its a good point to remember!  Black diamond indicates included, open diamond is not. They are settable in the right click context menus.
0xDEAD
Message 14 of 18
(1,134 Views)
Good to know, I never noticed that.
Message 15 of 18
(1,119 Views)
This is still an issue in 21.0.1f2. It just really bit me badly.
One of the benefits of the built-in mouse wheel support is changing the increment based on the position of the cursor, I can not find a way to do this without the built-in mouse-wheel support.
Message 16 of 18
(818 Views)
If this is still a problem (not tested), you can easily detect a rollover in software and act accordingly before the rest of the code sees it.
Message 17 of 18
(792 Views)
Altenbach,
Thanks for the response. My post was intended to just (re-)report the issue, but now that you mention the workaround... here is what I have considered:
Let's say that my limits are 1-100, I put a hard limit on the absolute difference between the old and new values and just ignore anything that is greater than half the range (50).  Is there a better way?
Message 18 of 18
(770 Views)
