Not sure how to implement the 'Create File with Incrementing Suffix' VI to save images
@navman74 wrote:
No I didn't what is supposed to go in the file path box?
Browse for the same path that you would if you were using your original code with the filepath dialog. Make sure you are using the Path Only VI I included above.
Bob, your link isn't set up properly.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 11 of 12
(1,170 Views)
Oops, my bad.  Search for "How to save acquired Images", June 21, 2016.  My reply with a Snippet is on Page 2.
Message 12 of 12
(1,153 Views)
