07-04-2019 05:26 AM
Hi so I have an Agilent 82357B sourcer unit and keithley 2450 device
I want to set up to output a constant pulse current Not measurement (for example, if you set 0.2mA, 1 deley time and 10 count then you can see 10 pulses(0.2mA))
But now I cant seem to get it to work.
I attached source code, screenshot and driver
Any help is appreciated.
Thanks in advance
07-04-2019 06:30 AM
You only mention that "it doesn't work", but don't describe what that means.
Can you communicate with the instrument?
Do you get errors message?
What part are you asking for help with?
Craig
07-04-2019 08:14 AM
I'm sorry to describe vaguely
I mention that "it doesn't work" means
Just I want to sweep current source, but it works sweep current and acquire measurement
So How to make 'only sweep current pulse source program`
I think that modify some code, but it's so hard to me..
please help me
Thank you for comment
07-05-2019 03:08 AM
2450 you used is a source measurement unit, SMU.
SMU measures the power source it generates for feedback.
So it is a very native operation.
if you don't want to see the measurement operation, just delete your graph.
07-08-2019 09:43 PM
Right I don't want to see the measurements and delete the graph
Actually, What I'm trying to do right now is
With sourceMeter, the current is swept to the muscle.
This is to measure the voltage as NI pxi-4071.
The first step is to sweep only, but the measurement results in errors.
