09-20-2016 06:29 AM
Hello All,
I am developing an user Interface TestStand Using LabVIEW, While Doing so i have used few Sub VI's which is already being developed by NI.
I need to update the VI Icon with my standard icon but its not allowing me to do.
Anyone faced Similiar error/is there any other option to edit?
09-20-2016 06:58 AM
09-20-2016 07:07 AM
Moved to different location(Project Files), Still not able to edit
09-20-2016 07:53 AM
You are an expircend forum user, so you know that the best way to help you, is to share your code, that you have trouble with, with us.
09-20-2016 08:05 AM
@dkfire wrote:You are an expircend forum user, so you know that the best way to help you, is to share your code, that you have trouble with, with us.
Sorry about that, as it is a generic VI developed by NI, I did not attach the code.
For Full library files:
Library path: C:\Users\Public\Documents\National Instruments\TestStand 2014 (64-bit)\UserInterfaces\Full-Featured\LabVIEW\Source Code\TestExec.llb
09-20-2016 08:09 AM
I have no problem to edit the icon of that VI.
Remember when you use a VI from an example to only edit a copy of that example, not the example itself.
09-20-2016 08:13 AM
So its not possible to customize an existing example VI.
09-20-2016 08:23 AM
It is, and it should be, but just remember not to overwrite the examples.
If you overwrite the examples, then you will loose your base example.
09-20-2016 08:42 AM
Sorry for Long Conversation. I made a duplicate copy in my work directory but still i am not able to edit.
I can create my own VI, but need to understand why i am not able to edit that VI. and also wanted to know how to Prevent from editing, so that i can able to use for future requirements if any.
Are you able to edit icon for the attached VI (Earlier Post)?
09-20-2016 09:13 AM
