Not able to create OUT file with "nidll_vxworks" in Matlab for use with the LabVIEW SIT 2010 and a cRio 9073, sh.exe error
I am trying to compile an OUT file for my Simulink model using "nidll_vxworks" and run it using the Simulation Interface Toolkit for a cRIO 9073 . I am able to compile the DLL file using "nidll" and succesfully run the simulation using my PC as the host.
I already downloaded the "gccdist" and "vxworks61gccdist" folders and copied them to "c:" When I build the model in Sumulink I get the following error at the end of the process (at the same time windows tells me that "sh.exe" has stopped working). If it matters I am running Windows 7 64bits, but using Matlab 2009b 32bits and LabView 2010 32 bits. ANY HELP WILL BE APPRECIATED. "QofV" is the name of my Simulink model and I changed to "XXX" parts of the file path.
### Linking ...
rm -f "QofV.out" ctdt.c;nmppc QofV.o QofV_data.o rtGetInf.o rtGetNaN.o rt_logging.o rt_look.o rt_look1d.o rt_nonfinite.o  nidll_main.o rt_sim.o ode8.o    | tclsh c:/gccdist/WindRiver/vxworks-6.3/host/resource/hutils/tcl/munch.tcl -c ppc > ctdt.c
abnormal program termination
C:\Users\XXX\AppData\Local\Temp\make426012.sh: fork failed: no child processes [1]
make: *** [QofV.out] Error 1
### Real-Time Workshop build procedure for model: 'QofV' aborted due to an error.
### Linking ...rm -f "QofV.out" ctdt.c;nmppc QofV.o QofV_data.o rtGetInf.o rtGetNaN.o rt_logging.o rt_look.o rt_look1d.o rt_nonfinite.o  nidll_main.o rt_sim.o ode8.o    | tclsh c:/gccdist/WindRiver/vxworks-6.3/host/resource/hutils/tcl/munch.tcl -c ppc > ctdt.c
C:\Users\XXX\AppData\Local\Temp\make426012.sh: fork failed: no child processes [1]make: *** [QofV.out] Error 1 ### Real-Time Workshop build procedure for model: 'QofV' aborted due to an error.>>
### Linking ...rm -f "QofV.out" ctdt.c;nmppc QofV.o QofV_data.o rtGetInf.o rtGetNaN.o rt_logging.o rt_look.o rt_look1d.o rt_nonfinite.o  nidll_main.o rt_sim.o ode8.o    | tclsh c:/gccdist/WindRiver/vxworks-6.3/host/resource/hutils/tcl/munch.tcl -c ppc > ctdt.c  abnormal program termination C:\Users\XXX\AppData\Local\Temp\make426012.sh: fork failed: no child processes [1]make: *** [QofV.out] Error 1 ### Real-Time Workshop build procedure for model: 'QofV' aborted due to an error.>>
Javier Ruiz - Partner at JKI
jki.net
vipm.io
(3,760 Views)
In addition. I manage to create the QofV.OUT file sometimes. It looks very random to me. With the same Simulink model I get the error most of the time, but once every 100 compilations it works. I am thinking there is another process that makes the sh.exe crash.
jki.net
vipm.io
(3,753 Views)
Accepted by topic author jarcTek
GCC 6.1 is only suported on Windows XP.  It is almost noted in the readme_sit_vxworks.txt that can be found in C:\SimulationInterfaceToolkit\xxxx\VxWorks (where xxxx is the version of SIT).  It says:
*Known Issues
- The WindRiver GNU Toolchain 6.3 and 6.1 do not work on Windows Vista.
To be more explicit it should be "Vista and later".
Carl L
(3,733 Views)
Ok. Thanks.
Do I have an option if I want to use my Win 7 machine?
Thank you again for your reply!
jki.net
vipm.io
(3,728 Views)
Hello jarcTec,
I am not sure right now if you can do it, but this tutorial might help, also everything was made in Winddows 7 in this one.
http://zone.ni.com/devzone/cda/tut/p/id/11654
Take a quick look and let me know if it works!!!
Luis Elias
NI VeriStand and HIL Product Manager
(3,720 Views)
Hello Luis.
I was actually using that tutorial when I ran into the problem described above. It may not be an issue with Windows 7 but with Windows 64 bits in general.
I managed to get an XP 32bits machine and compile the out files there without a problem.
jki.net
vipm.io
(3,716 Views)
