08-29-2017 10:04 AM
When im trying to use Labview Vision toolbox im getting following errors. I have installed all drivers and i able to See CAM0 in labview but camera isn't capturing images. please check image for error
Thanks in advance
08-29-2017 01:07 PM - edited 08-29-2017 01:07 PM
It most likely means that your USB camera doesn't fully comply to the USB Video Class specification. The Linux driver on the myRIO is a standard driver from the Linux kernel project and does implement a certain subset of functions from the USB Video Class specifications. Your device may use a non standard function somewhere or not implement a specific feature completely correct. Or the Linux kernel driver has a bug that doesn't fully work with your camera.
NI is very unlikely to fix this driver as it is not their product and your best bet is to try with a different USB camera.
09-06-2017 04:04 AM
Hello ,
Thank for pointing out issues. Will you please suggest a list of USB camera that is compatible with NI MyRio or link where I can find the list of USB cameras Compatible with Device.
Thanking you for your precious time.
Kumar K
09-06-2017 04:05 AM
Hello ,
Kumar K
