Not able to capture trigger in exe.
Hello
I am using LabVIEW 2012 SP1.  The hardware is PXIe 6363 card .
I have a VI which starts acquiring data on  Digital trigger( falling edge). The digital trigger lasts for around 100ms.
The trigger works perfect in when run the VI. But when I make the application exe, the trigger is missed and I get timeout error.
What is the difference between the VI and the exe?
In the VI , the trigger is captured everytime and data is acquired but this does not happen in exe. Please let me know.
(2,084 Views)
Does this happen when you run the exe on the same pc as you built it on or only on a pc without the LabVIEW development? On a new pc, you have to install the DAQmx runtime and the hardware configuration from MAX on the development pc. Both of these options are available when you create the installer.
(2,069 Views)
I ll check the DAQ run time and the installer settings. Thank you
(2,049 Views)
