Non-Linear Fitting VI Issues - LV 2017
No matter what I try after making a VI to define f(x, a) for my nonlinear fit, for some reason I keep getting a class mismatch between the reference and the input on the Nonlinear Curve Fit VI. I was wondering if this was an issue with my VI even though the connections all seem to be correct.
(1,956 Views)
Accepted by topic author tmbates12
You changed the output connector for the derivatives. Even if not connected, it needs to be a 2D array (you made it a 1D array for some reason).
If you still have problems, feel free to attach the caller too.
Also, if you use a static reference, make sure to make it strictly typed.
(1,939 Views)
