I'm having some problems with picking up what i assume are noise peaks while running labview VI's. These peaks are not present when i look at MAX... only through labview. For example, i get periodic peaks of +- 2 degrees in a simple TC VI. Same thing occurs with other VI's i have created. Could i be missing something in my programming, or is it simply a physical connection somewhere?
Mike
