10-17-2017 01:04 PM - edited 10-17-2017 01:05 PM
Just click on Test Panels so you can view your signal. It should come up selecting AI0 already, which I believe the BNC connector connects to AI0 for + and AI8 for -. It should also be in differential mode. Now you can test whether or not your signal looks correct. If it doesn't, and you're using the same BNC cable that went into the O-scope, I could only guess that your BNC-2110 accessory is not plugged in firmly, but I've never used one of those before.
10-17-2017 01:06 PM
@Hooovahh wrote:
Have you tried reading the fun manual? (RTFM) Here's a few links on how to use the test panel. Nothing extra should need to be configured.
Ha, I thought the F stood for Friendly 😛
10-17-2017 01:13 PM
Yes. I tried to use the Testing panel in the MAX, and got the values as I mentioned above, just constant signal, rather than supposed pulse signal. I don't know why like this.
10-17-2017 01:19 PM
Did you increase the aquisition rate to something higher than 1 kHz. 400µs is a pretty short pulse, not visible at a rate of 1 kHz.
Regards, Jens
10-17-2017 01:21 PM
Yes. I considered this thing, and set the frequency as 100 kHz.
11-08-2017 09:22 AM
Hi, I'm not sure if there is anyone still focus this topic. Anyhow, I find the reason of my problem. The reason is either the BNC 2110 board or PCIe 6363 card has a hardware malfunction. I switched the signal to another BNC2110 & PCIe 6321, and can get the input signal.
Thanks.
