No output from DAQ
Are you using the same hardware for input on both computers?
You might have wired the input to a different channel on the laptop if you have different hardware if you are not getting any errors.
Message 11 of 18
(795 Views)
Yes I am and everything the same just one of has professional labview and the other doesn't.
Message 12 of 18
(791 Views)
So I will go back to what hardware are you using?
On the laptop can you go into MAX, find the device, run the test panel and see data on the input channel?
There also might be a properties tab for the device to set up accessories.  Is it setup the same as the development machine?
Message 13 of 18
(782 Views)
I did everything seems the same
Message 14 of 18
(771 Views)
Did you get data when you ran the test panel on the input chanel?
Message 15 of 18
(758 Views)
No I did not get anything. Everything look the same and working on the computer I have developed the program on it. Even when I run the exe on it everything working. But when I use exe on the second laptop the sequence of the program is working and just I'm not getting the reading the data. I have double Check the Chanel's names and re-install the drive.
Do you know what's the requirements for the exe file to work in any computer?!
Message 16 of 18
(751 Views)
Since you aren't getting a signal with the test panel in MAX, then your problem is not related to LabVIEW or your exe. If you don't get any error either, then double check the wiring.
Message 17 of 18
(746 Views)
Okay thanks
Message 18 of 18
(744 Views)
