No menu on double-click with the right button
@Intaris wrote:
Using a sub-vi to simulate a menu is an avenue I'm not willing to investigate.
It's far too much work for something which is 99% available already.
Well, I did post the code that does all the heavy lifting for that earlier (reply 7), so that does get you over some of the hurdle.
As for having focus, my example uses the coords as part of the function call, but I don't know if that affects out-of-focus windows (although, like I said, I do think this method is flimsy).
___________________
Try to take over the world!
Message 21 of 27
(718 Views)
I believe the original comment was to have a "pretend" menu..... Maybe I misunderstood.
Message 22 of 27
(705 Views)
Yes, and I will point you again to reply 7, where I posted such code.
___________________
Message 23 of 27
(700 Views)
You meant he OpenG version?
I don't have OpenG installed.  I don't use OpenG.  I didn't even look at as you mentioned it needed OpenG files.
Shane.
Message 24 of 27
(689 Views)
Yes. Looking at it now, it only uses a few OpenG VIs, but it's up to you whether you want to deal with it or not.
Another option, if you're not comfortable with the simulated click, is to send a mouse click message to the window. I don't know if that's any more stable, but it's an option.
___________________
Message 25 of 27
(682 Views)
ZM2376 LCR meter by NF Corporation does not respond to mouse click using labview. How can I overcome it?
Message 26 of 27
(545 Views)
What the relation of your question to this 4 (nearly 5) year old thread??? Smiley Surprised
Regards, Jens
Kudos are welcome...
Message 27 of 27
(538 Views)
