12-20-2020 06:45 AM
Hi all
I try to make a serial connection between Keysight 34970A to PC via RS232 the problem that i faced is that the COM port doesn't configurated in NI-MAX .
THANK YOU
Solved! Go to Solution.
12-20-2020 08:30 AM
Did you install NI-VISA? Did you install the driver for the serial port?
12-20-2020 11:29 AM - edited 12-20-2020 11:34 AM
@Haythem96 wrote:
Hi all
THANK YOU
I work with these all the time, here's some advice...
ONE more thing: The black serial cables that come with the 34970A are crap! The do not have the hardware handshaking lines inside. So the highest setting the instrument can run reliably using them is 9600 baud Xon/Xoff flow control.
Buy some "real" serial cables and that instrument has no problem running at 1115200 baud with RTS/CTS flow control.
12-22-2020 03:07 AM
yes I did
12-24-2020 04:30 AM
Thank you
