12-12-2006 09:46 AM
12-13-2006 10:21 AM - edited 12-13-2006 10:21 AM
Hi wd8ivl,
When you get the error, does the dialog box have a link to click for more
information about the error? If so, please click on the link and post
which dll is being referred to in the dialog box. (Please refer to the
diagram below for more information.) If
this is not the case, can you please either attach an image of the dialog box
you are getting, or the exact wording of the error message?
Best of luck on your application, and have a great day.
Message Edited by cphuong on 12-13-2006 10:21 AM
Message Edited by cphuong on 12-13-2006 10:22 AM
12-13-2006 10:38 AM - edited 12-13-2006 10:38 AM
Ching,
Maybe you are using a different version of Labview or a different O.S., but my error box doesn't display an option for more information.
If I can find what is telling it to load, (maybe from the registry), I can fix it.
For what ever reason, I can't seam to attach a jpg of it.
Mike
Message Edited by wd8ivl on 12-13-2006 11:42 AM
12-14-2006 04:33 PM
12-15-2006 07:20 AM
Ching,
Thanks for the reply.
My local NI rep (Som S.) was in here yesterday. He re-installed the LV 7.0 runtime, MAX 4.0 and the NI-VISA runtime...nothing helped.
After that, a call to Austin solved the problem. (I don't know who he spoke with)
He was told to disable the "nipxirmu" service. That solved the boot-up error, and my applications run fine (I'm not using anything PXI)
Mike
12-18-2006 12:46 PM
