Nicolet NRF ActiveX Reader
I've downloaded and installed the Nicolet NRF (Nicolet Recording Format) ActiveX Reader Dataplugins on my PC. It works with Diadem 9.1 but I want to use it in LabVIEW (version 7.1). Any thoughts on how to read data file in NRF format in LabVIEW?
Lancer
(4,370 Views)
I have a sneaking suspicion that someone (NI or elsewhere) has already created a suite of LabVIEW VIs to serve as a driver for the Nicolet NRF Reader ActiveX API, but it wasn't immediately apparent where to find it. As a one-time user of an old Nicolet 4094 scope, I figured I'd try an example myself.
After I downloaded the installer from the NI site and installed it, I noticed two things that helped me figure out how to proceed:
1. Now when I put down an "Automation Open" node on my LabVIEW diagram and choose Select ActiveX Class >> Browse, I see two new Nicolet type libraries. I figured the Recording Definition 1.0 was the one to pursue.
2. The installer placed a sample NRF file at <National Instruments>\Shared\USI\Examples\Nicolet that seemed like just what I needed to determine if things were working or not
I started my standard ActiveX technique of blundering around with various properties and methods and their results, and then I thought better of it and searched for and found an excellent SDK reference for the library from Nicolet here:
http://www.nicolet.nl/Pdffiles/NRFReader.pdf
With that, I was able to slap together an example that opened an NRF file and displayed an arbitrary channel of data. A few caveats:
- I didn't bother to close any ActiveX references, which is a bad idea for a real app
- The SDK makes it clear that getting properly scaled and stitched-together data for an arbitrary NRF file channel (in time as well as magnitude) is tricky, and I didn't worry about whether mine was scaled and stitched properly or not.
- I didn't quite understand why it was necessary to ask for a certain number of data points, nor did I understand why the method to get channel data returned a 2D array.
With those grains of salt, it looks like this example would be a good jumping-off point for you. One thing I would suggest is considering whether it might not be easier to make DIAdem do the work for you. I'm not very familiar with it, but I know you can communicate easily with DIAdem from LabVIEW. Perhaps you could ask it to read these files for you and return the data to LabVIEW; it would be one additional level of overhead beyond the ActiveX layer itself, but if things already work well from DIAdem, it would save the effort of building a driver in LabVIEW.
My two cents. The attached example is for LabVIEW 7.1 and assumes that the Nicolet plugin is installed.
Take care,
John
(4,358 Views)
Thanks Johnner, I will certainly try your suggestions. I did come across the SDK from Nicolet but the focus was on using Visual Basic and I'm not very familiar with VB.
(4,341 Views)
Thanks Johnner for the great help!
Vincent Carpentier, Ing./Eng.
CLA, CPI
Neosoft Technologies
www.neosoft.ca
DQMH Trusted Advisor
(3,902 Views)
