01-10-2022 02:43 AM
My NI-PXIe 4492 device is in the case of NI 8821. When I connect one of the channels of NI-PXIe 4492 with the probe of the oscilloscope, the oscilloscope does not show the waveform. I want to know why, and what can I do to fix it. Thank you very much!
01-10-2022 08:58 AM
For your information, PXI 4492 is an Analog input module, you need a signal generator to provide signal to the module. Connecting two inputs together will not give any signal - 4492 and scope.
01-11-2022 07:29 PM
I think I understand. Thank you so much for your answer!
02-24-2022 02:21 AM
As you explained, I've been looking for a lot of ways to do this, but it may be a little difficult for me, the problem is not solved, I would like your advice, you think if I want to use the oscilloscope connection NI 4492, what am I supposed to do? Thank you very much!
02-24-2022 08:30 AM
4492 is an analog input card, it consumes signals like an oscilloscope.
Always connect a signal output to signal input. You do not connect two inputs together without a signal output as it does not logically provide any functionality.
Please elaborate on why you would need to connect a scope to 4492 and what you have tried.
02-25-2022 12:55 AM - edited 02-25-2022 12:57 AM
I tried to connect the oscilloscope to the NI 4492 because when NI 4492 was used for data acquisition, I wanted to be able to display the 4492 results on the oscilloscope. The eight channels are supposed to connect the signal to be collected, so I don't know how to connect the oscilloscope to observe the waveform when the 4492 is collecting the signal.
02-25-2022 08:33 AM
Please share details of cables, connectors used in the connection and if possible picture of the cable connections.
Where does the signal come from? a microphone or accelerometer? what model?
What kind of oscilloscope probes do you have?
02-26-2022 12:22 AM
我还没有接信号,我只想知道,以后我要采集数据的时候,NI 4492通道接了信号,如果要外接示波器怎么接?附上我目前组装的硬件设备。
