i´m using the default NI-OperatorInterface (with some modifications) which is located in the TestStand-Directory in C:\Programme\National Instruments\TestStand 3.5\OperatorInterfaces\NI\Simple\LabVIEW.
My problemis that i dont know how to get a "sequence-context" in here so that i can read and set the TestStand-StationGlobals.
I want to add an event-case "value change" in the attached screnshot so that i can press a new button in the OP that is recogniced by the event, and then this state should be written to the StationGlobals. But i have no sequenceContext to execute the "Set Property Value.vi"
When i check the properties of the ExecutionView Manager then there is a sequence-context, but when i use it, then its not working. (see attched screenshot)
TFTC
Message Edited by OnlyOne on 08-09-2007 04:57 AM
