04-07-2007 04:03 AM
This message is request help of using Newport Dual-Channel Power Meter 2832-C. We are doing some project using the LabView to control and take the record from the Meter. Could you have some LabView file via
04-07-2007
06:03 PM
- last edited on
03-11-2025
03:45 PM
by
Content Cleaner
The Instrument Driver Network has a driver for it.
04-08-2007 11:17 PM
04-09-2007
08:27 AM
- last edited on
10-07-2026
03:50 AM
by
Content Cleaner
Hi BelieverPaul,
Am I correct to understand that you found a GPIB instrument driver for your Newport device, but not a serial driver? All drivers (whether they are serial, GPIB, ethernet or USB driven) can be found on the Instrument Driver Network, linked in an earlier post. If a serial driver is not listed, we do not currently have that option available. I did a search for the Newport drivers myself and it appears that they are not NI-certified (ie. not developed/tested by National Instruments). You may want to check with Newport to see if they have some LabVIEW drivers that have not been posted on our website. If not, you always have the option of creating your own programs based on VISA to communicate serially with your device! You can also submit a request for a new driver here. Hope this helps!
04-09-2007 09:17 AM
04-10-2007 02:58 AM
This mail is sent to request a help.
I have a GPIB cable
, Would I control the Power Meter 2832-C via the GPIB through ESP 300 controller? If it is work, which command of ESP 300 should be use?
Please feel free to reply
Thank you very much!
Paul
10-4-07
04-10-2007 08:21 AM
04-10-2007 10:22 PM
Thank you a lot!
Now, I will try my best to modify the GPIB driver to Serial Port driver of Power Meter
09-19-2012 02:16 PM
Do you manage to the Labview Driver for Model 2832-C working even with GPIB? I try to use the driver but it shows "error -288 command not available"
Thank you
Regards
Jaz@
09-24-2012 04:24 PM
Does anyone have New Port 2832-C driver. I have the NI labview instrument driver for the instrument installed but i dont really know how to write command to start the measurement and stop the measurement
