New measurement starts with the last measurement value before program stop
New measurement starts with the last measurement value before program stop. This is very embarrassing because we finish at a high measured value and start with small value, which can not be seen on the autoscale screen due to the memorized high first value. We use NI PCI-6220 DAQ board and software written in LabView 7.1 using Express VIs and running in the LabView environment. The program (attached) every half second measures 3 AI channels, filters and scales the data, visualizes, averages and saves it in a file. Please advise me how can I avoid this problem. Please note that I am not very experienced in LabView.
(2,033 Views)
I can not run your vi, but if you initialize your controls you should be ok.
Look at the picture
(2,027 Views)
