New VIs for Override not showing up on the Overrides list
I've been using LabVIEW OOP for some time now and have been creating overrides of parent methods without giving it much thought until recently. I tried to create an override for one of my VI drivers but none of the parent methods were showing up on the New VIs for Override dialog box with the exception of the accessors. Any ideas about what I may be doing wrong?
Thanks in advance!
(1,332 Views)
The obvious thought is that the class controls/indicators in the parent class VIs aren't actually Dynamic Dispatch on the connector pane.  You didn't specifically say, so maybe it's been overlooked?
Tim Elsey
Certified LabVIEW Architect
(1,329 Views)
Hello elset191,
The class controls and indicators were set as dynamic dispatch in the parent class. I created the methods by selecting VI from Dynamic Dispatch Template. I also checked the item settings under properties and I couldn't figure out what I did wrong. I've attached the project file.
(1,316 Views)
Accepted by topic author SolPS
Ah, I think none of them are showing up in the list because all of them already have overrides in the child. (except the accessors, which are in the list)
Tim Elsey
(1,311 Views)
Hello Tim,
Thanks for your reply. For some reason I thought I must have done something wrong which caused the VIs not to show up on the list.
Thanks for prompt response. Much appreciated!
(1,302 Views)
