New VI - default window size
Highlighted
Thanks for the idea. Ideally I'd like to avoid the requirement of adding the template to each and every project.
I wonder if this can be modified by editing some of the core project provider framework VIs/ LabVIEW VIs.
I've also noticed what appears to be a bug with VIs created using the override method (lv_new_vi.vi).
When attempting to add the newly created VI to the project using the App.Project.ActiveProject -> MyComputer -> AddItmFromMemory, it fails with Error 1004: The VI is not in memory. However, if I run the lv_new_vi.vi manually it works without any problems.
Using LV2018 32 bit
Highly recommended open source screen capture software (useful for bug reports).
https://getsharex.com/
Message 11 of 12
(242 Views)
This works for me except I'm not able to save or save as the new VI, named Untitled 3 Front Panel, same as regular VI. I just got a 32" monitor and the LabVIEW new VIs are way too big :-).
cc
Message 12 of 12
(63 Views)
