New LabVIEW 2019 Feature: Create Constant, Create Control, and Create Indicator
I've had the 'Create' menu items at the top of my right-click menus since LabVIEW 2015 because I've been using this shortcut menu plugin the whole time. I convert case structure tunnels to the selector several times a day, and I configure the loop indexing options on loop tunnels several times a day. I have adjusted appropriately to immediately start moving down to the right spot in the menus for both of those actions. I'm confident y'all will too.
DNatt, LV R&D
Message 11 of 30
(321 Views)
Thank you pauldavey, for asking this question
Thank you NI, for the escape hatch
I really want that "find terminal" at the top of the right-click context menu, rather than "Create Constant, Create Control, Create Indicator"
Message 12 of 30
(230 Views)
Highlighted
Agreed a lot with your statement.  Right Click >> Clean Up Wire is my habit like getting remote on coffee table without watching it.  Since LV 2019, I noticed myself create unnecessary constant instead of cleaning up wire, like jar of jam is located instead of remote.  I have to wipe my hand and get the remote.
I vote on disable the new shortcut by adding the INI token.
Message 13 of 30
(175 Views)
Ever since I found out about the feature, I have changed my habits to use Ctrl+U to clean up my wires instead of the right-click option that I have used for well over a decade.  I'm still in 2016 and I have found myself using the right-click option maybe once or twice in the last month.  If you give it a true honest try, I believe you can change as well.
GCentral
Message 14 of 30
(164 Views)
Before knowing about the INI token, Ctrl+U is the first thing I came up with and tried to get used to.  Believe me, I am not joking but serious to say that I hold mouse on my right hand and place left hand on keyboard.  Then, Ctrl+U forces me to stretch left index finger and little finger.  Maybe my left palm is too small, but I gave up that workaround.
Besides, what I do after right click is not only Clean Up Wire, but also other things, as other folks already mentioned, like changing visible items, switch with case selector, etc.  There is not only remote but also other stuffs on coffee table...
Message 15 of 30
(158 Views)
Me too. But instead of trying to stretch with my pinky on the left Ctrl and my index finger on U, I shift my left hand to the right side of the keyboard, with index finger on right Ctrl and pinky on U.
More generally, unless I'm typing words/sentences (like in free labels, control labels, etc.) my left hand usually shifts around on the keyboard, like if I'm using Quick Drop and need to drop that rare shortcut object that uses right-side keys.
DNatt, LV R&D
Message 16 of 30
(153 Views)
Below are my gears and settings.  Mouse is track-ball, and if I shift my left hand to right, my left hand crosses over my right hand on the mouse and it is very hard to do.
Maybe I actually started some jokes so, I should stop here and say thank you all so much to make LabVIEW better development environment as always.  I am looking forward to hear more opinions about this topic.
Message 17 of 30
(142 Views)
Any chance your right pinky could reach over from the mouse and hit the Ctrl key?
DNatt, LV R&D
Message 18 of 30
(138 Views)
@cbutcher wrote:
@Hooovahh wrote:
Same with right clicking a boolean going into a Case Structure.  I want Replace With Case Selector to be the top item
Wow. Never knew this feature...
Edit: Works with error wires too. That's fantastic.
You can do booleans, integers, enums, strings, and error clusters. (You can do others too, but they result in broken wires)
Message 19 of 30
(136 Views)
Thanks much for the advice.  I gave it a shot, but it requires some move on my right hand off to the right Ctrl.
Message 20 of 30
(131 Views)
