12-10-2007 11:44 AM
Thanks for the quick response. I will try the select_hyperslab function. BTW I am trying to use the HDF5 interface library by Jason S, with LabVIEW 8.2. This is my first experience with HDF5 and YES the learning curve is steep. I will try to post a new thread, I just realized how old this one was.
gary
12-10-2007 02:15 PM
I am trying to use the hyperslab function but I do not know what to input for Start, Stride, Count, or Block. Could you be a little more specific. Any help is appreciated.
Gary
12-10-2007 02:32 PM
12-10-2007 03:55 PM
12-10-2007 04:38 PM
12-11-2007 09:15 AM
DFGray: Is there any other resources for help on HDF5? I cannot get to the point of reading the data. I am able to hyperslab OK (I think) but I cannot read the data. There seems to be very little examples or additional information, or maybe I do not know where to look. Any help would be appreciated, as I am running into a deadline.
gary
12-11-2007 09:40 AM
02-28-2012 03:08 AM
Hello
Thank you for an excellent addon to Labview. I have been using it in conjunction with MATLAB with great success so far.
Now however I have run into a problem. I have upgraded Labview to 2011, 64-bit and the HDF5 library is no longer working since h5helper is compiled for 32-bit.
Has anybody recompiled Jason D's sources successfully for any platform? Or are people using other solutions for 64-bit operating systems?
Also, if I use newer versions of the HDF5 libraries (i.e precompiled binary version 1.8.8) from hdfgroup then some calls are broken because the library no longer contains them.
Regards
Kalle
02-29-2012 03:49 PM
Hi Kalle,
I recommend reposting this as a new thread; I think it will get more attention that way and you may hear more what other developers are doing on 64-bit systems.
As far as I can tell, this isn't something we really support, atleast on Windows 7 64-bit system. Are you using executables/code from our website? or are you using code that Jason D wrote?
