Neural net - putting weights into strings
I can try to help..
There's a few things I do not understand in your code...
For instance, why do you disable the ADD control?
Are you simply trying out code>  which is why you manually enter the translated string?
You need to flatten the variany yo string and write it to a file.  Read that same file each time you want to add more..
So in this example, you would not use the shift register, unless you want to have a list which restarts from scraych each time you run (restart) the code.
Message 21 of 24
(530 Views)
well yeah as you said I was simply trying out the code in this one and I had plenty of help too 😐
Message 22 of 24
(526 Views)
Do you know what I was describing?
I'm here on the forum ON & OFF...
Although I leave the computer at the site, I may not always be in front of the computer.
Let me know if you need help with what I described.
Message 23 of 24
(512 Views)
I know the flatten the variant part. The rest was kind of unclear for me. Sorry but im just noob here.
Message 24 of 24
(510 Views)
