08-31-2016 04:23 PM
Hi All,
I use Network Stream to communicate between a VI & Exe - here VI is the writer and Exe is the reader. While creating the endpoint I give a minimum buffer size, say 100. But when I actually write to the stream I input an array of DBL of size 1000. As per the documentation this situation is to be handled by LabVIEW & I am also reading all my 1000 values. But the memory keeps piling up for the Exe while LabVIEW memory is fairly constant or not increasing at a noticeable rate.The same happens even if I give the buffer size to be same as the expected array size.
Any earliest reply is really appreciated.
Priydarsini S
08-31-2016 05:12 PM
08-31-2016 08:11 PM
It could also be something not entirely related to the Network Stream. Code would help a lot here for us to help diagnose your issue.
