Need to run VI on boot or call from other application
I am looking for the most basic way to get Labview to run a VI upon bootup or call from another application (without having to hit the run button on the toolbar.) I would rather not have to build an application; I don't want to buy the professional version. I want my data acquisition to recover from a power outage reboot and keep going without human intervention. Is there a way to build an init that launches the VI in run mode? A colleague of mine has convinced me labview is the way to go for a new experiment, but this is one stumbling block that needs to be resolved. Thanks for any help you can give.
(2,170 Views)
Try setting your main VI to run when opened (VI Properties>Execution) and putting a shortcut to the VI in the Startup folder.
(2,170 Views)
Hello!
Dennis� idea sounds very good to me!
I just wanted to clarify that you do not need to buy the Professional version of LabVIEW to have Application Builder. You can buy the Application Builder itself as an add-on to the version that you already have.
Hope this helps!
S Vences
(2,170 Views)
i have used the startup folder to run labview vi's on several machines and it *can* work just fine.
however, sometimes there is a timimg problem and i get the message 'vi not found,' then labview usually loads the vi and runs - but leaves the error message, which can cause problems with later operations.
today i had this problem with a 3.4 G HP machine running Win200. Labview 7.1 & DAQmx.
my work around solution is to use the *MarcroScheduler* program. i call a it from the startup folder. it does the following
(a) start Labview 7.1
(b) wait 1 minute
(c) execute the vi.
without the wait state, Labview 7.1 will not run the vi properly.
good luck with your applications.
cu,
larryb
(2,170 Views)
