Need to print Front panel as html or PDF on Executable. Print VI won't work with Exe nor report Generation. Any clues ?
I need to print a front panel as pdf. I am able to use Report Generation and Print VI on development . But not on Exe. Any options ?
(1,143 Views)
You can use an Invoke Node on the reference to "This VI" with the method Front Panel -> Get Image. Save that image as a png or something, then use a command line interface to a PDF printer to print the image to a PDF file. (Or maybe you can just use the PNG image directly).
(1,113 Views)
