Via FieldPoint Explorer or FieldPoint 4.0, if you look at the channel configuration for the cFP-AI-110, you will notice that each channel has an attribute called Filter Setting. On the cFP-AI-110, each channel can be configured for 500 Hz, 60 Hz or 50 Hz. The fasted update rate for the module is to have all 8 channels set to 500 Hz. This will allow the module to sample at an All Channel Update Rate of 173 ms (~6 Hz). The cFP-AI-110 can not be configured to go any faster than 173 ms.
Aaron
