02-12-2016 08:02 PM
Hi everyone,
I am trying to make an interface and i need to display an image and then change it to other image if it satisfies the condition. I want this to happen in the same image box. Can someone please help me doing it?
Thank you.
Supreet Juneja
02-12-2016 08:37 PM
02-13-2016 12:41 AM
try this sample vi
I hope it could help
02-13-2016 05:38 AM
@Hatef wrote:try this sample vi
Hatef you posted a "greedy" VI, which contains a while loop without anything to slow it down to a sane level. It means, this example VI will try to run as fast as possible, and totally against good practices in LabVIEW. The while loop will be ok, if for example a 50 msecond Wait is placed inside...
02-13-2016 06:58 AM
02-13-2016 09:27 AM
02-13-2016 10:04 AM
02-13-2016 01:55 PM
If only two states (True or False) it is very easy to use a Boolean control and customize the control in the type def editor. The images are embedded in the true and false states. I use the tools DCS image navigator for the images. Much easier than a picture ring.
02-13-2016 03:58 PM
Hi Mike,
Thank you for replying. The image size is in KB's and dimension is 350x500.
Can you please explain how exactly rendering can be done?
Thank you again.
Supreet Juneja
02-13-2016 04:42 PM
