Need to change image on condition in labview
Highlighted
Hi everyone,
I am trying to make an interface and i need to display an image and then change it to other image if it satisfies the condition. I want this to happen in the same image box. Can someone please help me doing it?
Thank you.
Supreet Juneja
Message 1 of 11
(1,709 Views)
Highlighted
Well you can render an image into a 2D picture control. How big are the images? Are they static? What format?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(1,692 Views)
Highlighted
try this sample vi
I hope it could help
Message 3 of 11
(1,666 Views)
Highlighted
@Hatef wrote:
try this sample vi
Hatef you posted a "greedy" VI, which contains a while loop without anything to slow it down to a sane level. It means, this example VI will try to run as fast as possible, and totally against good practices in LabVIEW. The while loop will be ok, if for example a 50 msecond Wait is placed inside...
Message 4 of 11
(1,641 Views)
Highlighted
BLOKK
yes you are right
user should use wait or use event based on his code requirement
Message 5 of 11
(1,623 Views)
In addition to which, we don't know exactly what the OP wants since he hasn't responded to any further posts...
Mike...
LabVIEW Champion
Message 6 of 11
(1,599 Views)
Highlighted
Depending on the answers to Mike questions a Picture Ring control migt be a simple solution.
Ben64
The best way to say thanks is to give kudos!
Message 7 of 11
(1,581 Views)
Highlighted
If  only two states (True or False) it is very easy to use a Boolean control and customize the control in the type def editor. The images are embedded in the true and false states. I use the tools DCS image navigator for the images. Much easier than a picture ring.
Message 8 of 11
(1,550 Views)
Highlighted
Hi Mike,
Thank you for replying. The image size is in KB's and dimension is 350x500.
Can you please explain how exactly rendering can be done?
Thank you again.
Supreet Juneja
Message 9 of 11
(1,522 Views)
Highlighted
The way it usually works is that the student should show what has been tried and doesn't work. Attach your VI or a snippet. You still have to provide sine further information such as the source of the image - static, from file (png, jpg, etc), camera?
Message 10 of 11
(1,499 Views)
