Need spartan 3e driver for LabVIEW FPGA 2011
Hello, I'm looking for Spartan-3E driver for Windows 7 LabVIEW FPGA 2011. Thank you
Message 1 of 67
(6,593 Views)
Currently the LabVIEW FPGA Module can only target National Instruments' own FPGA products.  They do not have a driver that will support other boards with FPGA's.
But the following link might be useful for you.
Using LabVIEW FPGA with the Xilinx SPARTAN-3E XUP Starter Kit.
Regards.
Message 2 of 67
(6,559 Views)
The link is a driver for LabVIEW 2012. I need one for 2011.
Message 3 of 67
(6,551 Views)
You can request someone to downconvert those drivers for you.
That should not be a hard task.
Regards.
Mondoni
Message 4 of 67
(6,535 Views)
Hi token,
As was suggested, you should try to get the drivers converted on the version conversion forum here.
Andy C.
Applications Engineer
Message 5 of 67
(6,520 Views)
Hello all,
The conversion forum won't be able to downconvert driver software... I (or an Applications Engineer) can put the 2011 version up on our FTP site for you. It will only be available for 2 days, so I'll wait for confirmation that you're ready before I put it up (and give you a link).
Cheers!
TJ G
Message 6 of 67
(6,514 Views)
Just a note: there was an issue with LabVIEW 2011 regular that prevented the Spartan 3E XUP board from working, the support is only for 2011sp1, make sure that you have that version of both LV and FPGA installed.
Message 7 of 67
(6,500 Views)
yes, I would like you to upload the driver on FTP if thats possible.
Message 8 of 67
(6,483 Views)
Alright, it will be at ftp://ftp.ni.com/outgoing/Spartan3E_4_3.exe for the next 48 hours. Let me know if you have any trouble pulling it down.
Cheers!
TJ G
Message 9 of 67
(6,472 Views)
Hi Sir,
Would you please upload it to FTP again? From the thread, I could only find the driver for FPGA 2012, but the current version is 2011. Thank you for your help. 🙂
Kevin
Message 10 of 67
(6,413 Views)
