10-01-2012 08:49 PM
I have been looking for the link to LabVIEW 2011 SP1 Windows 32-bit download for an hour. I thought it might be incorporated into the SP1f2 version. Nope. SP1f1 version. Nope. The ni.com search can't find it, Google can't find it, I am stuck.
Solved! Go to Solution.
10-01-2012 08:58 PM
10-01-2012 09:47 PM
That worked, thank you very much. On the funny side, I was re-finding SP1 f1 and this thread is now the top ranked thread in Google for "ni.com download LabVIEW 2011 SP1f1".
09-23-2014 02:22 PM
I need this link too. the download button or link isn't showing up in my browser if it is still on the site. Just bought software and vendor says this is the only version our serial numbers will work with. Please send me this link.
Thank you
09-23-2014 02:24 PM
I should add I am refering to the page the link on this forum is pointing to is where i can not download from.
09-23-2014 02:29 PM
That page has the two hyperlinks present.
NI downloader: http://ftp.ni.com/support/softlib/labview/labview_development_system/2011%20SP1/2011sp1LV-WinEng_dow...
Standard download: http://ftp.ni.com/support/softlib/labview/labview_development_system/2011%20SP1/2011sp1LV-WinEng.exe
There is no "button". If you don't have these two hyperlinks on that page, then possibly there is something wrong with your browser?
09-23-2014 02:43 PM
09-23-2014 02:57 PM - edited 09-23-2014 02:58 PM
That I did not know. I guess the other question is even if you do have a right to the older version, would they not show up if you are not logged into NI.com at the time?
I would've figured that if you didn't have rights to a version, then you wouldn't be able to activate that version once you installed it. That you'd be left in evaluation mode. I didn't think that the website would block an attempt to download it.
EDIT:
I see that if you are not logged in, it says:
"Need previous versions? Access your SSP benefits by logging in."
09-24-2014 09:16 AM
http://www.ni.com/download/labview-development-system-2011-sp1/2871/en/ Have you tried registering your serial number to see if that provides the links?
If that doesn't work, send me a private message with a way to contact you and reply here so I can reach out and figure out a download option for you.
09-24-2014 09:16 AM
