05-09-2006 06:54 PM
05-15-2006 01:59 PM
A couple of things about your questions.
1. Doing this with a waveform graph is definitely not the best solution, because it has no history. That is why you are able to scroll on a chart and not a graph at run-time. If you do need the graph you can consistently have the waveform data be added to previous data, via a shift register, and then automatically change the start position time scale of the graph to keep up with where the data currently is. This solution is very very memory intensive and will dramatically slow down over time.
2. I am not sure what you are trying to multiply. If you are multiplying the entire waveform by some multiplier you need to make sure and scale the data points as well as the dt. I'm not sure if this is what you are wanting to do, but if it isn't please clarify more.
3. Again I'm not sure what you want to do here. Are you trying to mark a certain point in the graph at run-time? More clarification on this one please.
Let me know the clarifications and also if you have any questions about my explanation. Thanks
Tyler H
NI
05-16-2006 03:19 PM
05-17-2006 02:37 PM
05-24-2006 11:49 AM
