Need help with file I/O on GPIB file transfer!
I am reading a .CSV file of a waveform which consists of two columns,
one column is time & the other is voltage. I then convert this data
into a .ISF file format and write it to the hard disk on my PC.
Trouble is, when I open the .ISF file with NOTEPAD.EXE and copy the
data then paste it into a string control which sends the string to a
Sony/Tek AWG2005 Arb via the GPIB Write vi .. voila! perfect file
(8950 bytes), but when I just wire the converted data into a GPIB Write
vi I get only 984 bytes. I am using the Write Characters To File vi to
make the .ISF file.
Where is all the extra data coming from? And why don't I get it when I
am writing it to the file ?
I'm not very good with file I/O, so I really ap
preciate any help!
Mike Forkner
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 1
(3,584 Views)
