Need help with data acquisition for NI MyRIO 1900
Good day! DAQmx is not compatible in NI myRIO. Any alternatives you can suggest? We're working on acquiring ECG signals from electrodes. We're having a problem when it comes to displaying the acquired signal. Thank you!
(2,448 Views)
Accepted by topic author jamescpe
Hello Jamescpe,
MyRIO needs FPGA programming rather than DAQMX. The link here will help you underestand MyRIO programming.
Required and Optional Software to Program NI myRIO
CLD Using LabVIEW since 2013
(2,412 Views)
Although this won't help you right now, and might not help you later, I'm hoping it's worth pointing out that the new cRIO series (904x) have all the normal benefits of cRIO (RT, FPGA) with the added availability of DAQmx.
If you're currently testing something out and plan to expand later, knowing this might hopefully be useful.
GCentral
(2,403 Views)
