06-29-2018 10:12 PM
Good day! DAQmx is not compatible in NI myRIO. Any alternatives you can suggest? We're working on acquiring ECG signals from electrodes. We're having a problem when it comes to displaying the acquired signal. Thank you!
06-30-2018 03:20 AM
Hello Jamescpe,
MyRIO needs FPGA programming rather than DAQMX. The link here will help you underestand MyRIO programming.
06-30-2018 05:55 AM
Although this won't help you right now, and might not help you later, I'm hoping it's worth pointing out that the new cRIO series (904x) have all the normal benefits of cRIO (RT, FPGA) with the added availability of DAQmx.
If you're currently testing something out and plan to expand later, knowing this might hopefully be useful.
