12-01-2005 04:09 PM
12-02-2005 11:33 AM
12-02-2005 11:41 AM
I have one PXI-6509
I really only need to control 32 of the lines. So right now i have a case structure with 32 different cases. Each case has its own DAQ Assistant configured to a particular line. So depending on the number you input, you get that port/line set on or off.... This works, but its very inefficient... Its a small simple VI that is now over 3 megs in size (because of the 32 daq assistants). I wasn't sure exactly how to use the lower level VI's to control the DIO line. One thing in particular is that i dont know what my device number is... The help says that it is the number i speciified during the config, but i dont see how to specify that.
Jason
12-02-2005 11:50 AM
12-02-2005 11:50 AM
