Need help with Time Stamps and saving Strings in Excel
I did exactly as you said ...but the popup is there again 😞
Message 21 of 29
(2,605 Views)
Done...
Try this but it will not write the heading... A folder will be created inside that the files will be saved....
Smiley Happy
Message 22 of 29
(2,595 Views)
Worse :(, it doesnt even ask for the file....
am a beginner, can you please do something simple???
Message 23 of 29
(2,586 Views)
Hey it will not ask automatically create and write... Give the name and run it and then press start....Find a folder named data log in the path where you saved your VI
First try to understand the code then comment on it...Smiley Mad
Message 24 of 29
(2,584 Views)
I have attached the program/Module that i made...
The problem with mine is it overwrites the previous row/column instead of moving to the next row....
Message 25 of 29
(2,583 Views)
Make the Append to file true...
Message 26 of 29
(2,579 Views)
😞 this is really frustrating...am not blaming you...
I set it to true, still the Popup is there 😞
Message 27 of 29
(2,576 Views)
SORRY!!!!!...My Mistake 😞
I was not running the program from the Front Panel Smiley Sad
Guess would take some time to adjust to LabView
Message 28 of 29
(2,575 Views)
Then how were you running your VI????
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 29 of 29
(2,567 Views)
