Need help with Time Stamps and saving Strings in Excel
Hi, Am learing LabView now....and my task is
Everytime start button is pressed, a Random number must be generated.
The Random number is to be staroed in an Excel sheet such that the Random Number is in the first column and Time at which it was generated in the second column...
I used to work with Agilent Vee before and am finding it hard to adjust to LabView 😞
Sanjay
Message 1 of 29
(5,142 Views)
 I have attached a vi... I Guess that will give you an idea to meet your need... Use an Event structure for capturing the start button status and do the coding inside that....
Message 2 of 29
(5,130 Views)
Am using LabView 8.6 😞
Message 3 of 29
(5,128 Views)
Am making the same mistake again...Smiley Sad...
Here yougo in LV 8.5 version....
Message 4 of 29
(5,125 Views)
Why did they have to switch from Agilent Vee to Lab View 😞
Life was far more simpler back then ...............
Message 5 of 29
(5,122 Views)
I Guess the NI people can Answer this question better..... What JK1 whats your opinion.....?????
Life will be much more simpler + Happy when you learn LabVIEW (Joy of coding).... Smiley Wink
Message 6 of 29
(5,119 Views)
One last question...what is the purpose of the case structure here??
Message 7 of 29
(5,108 Views)
That I have used to give the Headings to the columns...( as you see after running the code)..Smiley Wink
Message 8 of 29
(5,106 Views)
There seems to be no undo button here in LabView 😞
Message 9 of 29
(5,101 Views)
The Program asks for a file to write.... I choose "test.xls" on the desktop but the the dialogbox keeps appearing again and again
Message 10 of 29
(5,096 Views)
