04-14-2011 01:42 PM
Hi all,
I need to get the run time down to under 1 minute, because i will be running it multiple times to scan an object for my senior project.
My "Master Program1" vi is currintly running at 2.35 minutes. My "Master Program1" is suppost to move a "Thorlabs t-cube dc servo motor driver (mn TDC001) and stage (mn Z625B) 1 mm. Then have my
"LC1-USB" CCD line camera take a measurement of the peak location, 23 times. Input the peak locations into an array and input the arrays into the graph.
For the sub-vi "modified detect peak positionv1" I just need to detect the max peak location of each measurement.
Also,for the sub-vi "ActiveX controller for stage1v2.2" is suppost to move the stage 1 mm.
My main vi "Master Program1" and my sub-vis "modified detect peak positionv1" and "ActiveX controller for stage1v2.2" are attached below.
I will be very greatful and give kudos to any one who can help.
Michelle2607
04-14-2011 01:55 PM
Your main program has a 23 iteration for loop. Your first subVI in that loop has a 1 iteration For Loop (why?), that has a 20 second wait in it. That means your Main program will run at least 460 seconds, which is over 7 minutes.
04-14-2011 02:21 PM
I agree with what Ravens Fan said. Also, you can use: Tools -> Profile -> VI Metrics... to monitor the timing performance of your VIs and find out what VIs are taking the most time to execute. Then, you can make modifications, and see if the performance improved.
04-14-2011 02:45 PM
I took out the for loop in the sub-vi "ActiveX controller for stage1v2.2" and it still takes 2.35 minutes to run. I do not know why you are saying it takes 7 minutes?
Michelle2607
04-14-2011 03:01 PM
Maybe I was not clear when I said
My "Master Program1" is suppose to move a "Thorlabs t-cube dc servo motor driver (mn TDC001) and stage (mn Z625B) 1 mm. Then have my "LC1-USB" CCD line camera take a measurement of the peak location, 23 times.
I meant that the For loop moves the stage 1 mm and takes a measurement 23 individual times.
Michelle2607
04-14-2011 03:06 PM
23 iterations of a for loop that has a subVI that takes at least 20 seconds. Multiply and you get at least 460 seconds.
So are you actually saying that a single iteration of your For Loop takes 2.35 minutes?
You may also want to put some flat sequences in and Tick count functions in between different steps in your SubVI so that you can see how long each portion of your code is taking to run. Or you could put a probe on each error wire in your ActiveX section of code. The probe will give you a timestamp of when that wire executes so that you can see if any portion of your ActiveX methods are taking longer than you think to run.
04-14-2011 03:24 PM - edited 04-14-2011 03:28 PM
No. I'm saying that to run the "Master Program1" vi through all 23 iterations of the For loop and put the arrays in the graph takes 2.35 minutes.
Michelle2607
P. S. I am using LabVIEW 8.6
04-14-2011 03:38 PM
That math does not add up. Unless you are running an ActiveX subVI that has a smaller wait statement in it than the one you posted.
04-14-2011 03:41 PM
I'll bet you need to use Automation Open and Close of your activeX object. They should both occur outside the main loop.
The HWSerialNum and Start/stop control should also be outside the main loop (thus not in the sub vi at all) but in the main vi.
Try that and tell how it works.
/Y
04-14-2011 03:53 PM
Yes, I gave you the wrong one. sorry.
Here is the right one.
Michelle2607
